Rubbed sunburst and purfling bleed http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=43345 |
Author: | Nils [ Wed Apr 30, 2014 9:49 pm ] |
Post subject: | Rubbed sunburst and purfling bleed |
I'm going to be doing a sunburst finish in the near future. I like the look of a rubbed burst to a sprayed burst, so ideally I'd like to rub it on. However, I would also like there to be herringbone purfling. Will the dyes bleed into the pufling causing problems? If so, is there anyway around it, such as sealing the instrument, then bursting over the sealer? Any tips on how to approach this before I start experimenting would be super appreciated! Thanks, Nils |
Author: | RusRob [ Thu May 01, 2014 12:08 am ] |
Post subject: | Re: Rubbed sunburst and purfling bleed |
You didn't say what type of finish you are applying but I would definitely seal it first. I would suggest sealing the perfling with a couple of coats prior to sealing the rest of the guitar. That will give you an extra barrier to protect the perfling from being sanded into. Again, not knowing what finish you are planning on using the procedure I would use with lacquer is this: Sand all imperfections out of the wood and finish with 320 grit. Seal the perflings with a couple of coats and lightly sand any rough edges down with 320 grit. Seal the rest with at least 3 coats sanding between coats to get a perfectly smooth finish. Then tape off the binding and perfling. If the prep isn't perfect any problems will be magnified 10X in the shading on your burst. Apply the burst and when you are satisfied with the results remove the tape from the binding and perfling and give it at least 3 or 4 coats of clear before touching a piece of sandpaper to it. When you have a sufficient build up then lightly sand and give it a couple more coats. Then you can block sand it to a smooth finish and give it a final coat of clear. The reason for sealing it with a few coats before doing the burst is that if you mess it up you can sand the burst off and start over without going down to the wood again. If you apply the burst directly on the wood with die you only have one shot at getting it right or you will have to sand the wood pretty deep to remove the burst. Plus as you mentioned the die will bleed into the perfling even if you tape it off. I would use the same method with different finishes whether it be Lacquer, Oil or French Polishing but the idea is the same, you want to be able to remove the burst if you make a mistake. That is how I would do it but I am sure someone else will have a different idea of how to do it. As with anything there are many ways to do things and no one way is the only way. Cheers, Bob |
Author: | Clay S. [ Thu May 01, 2014 6:52 am ] |
Adding to what Bob said - after removing the tape over the purfling you can scrape the purfling with a razor blade if the color has bled onto it. When applying the first couple of clear coats over the burst and purfling make them light "mist" coats to lock the color in place without having it bleed onto the purfles (if it does you can scrape them again). |
Author: | Nils [ Thu May 01, 2014 8:29 am ] |
Thanks Bob! I will be using lacquer to finish. So just to clarify, the dyes (aniline dye) can go over the sealer (vinyl sealer)? This wont cause issues with the lacquer burning into the sealer? |
Author: | RusRob [ Thu May 01, 2014 9:02 am ] |
Hi Nils, I have never used dies to hand rub a burst before so I would try it on a test piece first to be sure. I do my burst in a more traditional way using tinted lacquer and spraying them on so a rubbed burst is noting I have any experience with. However I would suggest not applying the dye over a sanded surface since it will enhance even the finest scratches and imperfections. If it were me doing it I would probably spray a coat or 2 of thinned lacquer over the sealer first just to be safe. I say thinned lacquer because you do not want any orange peel or dry spots prior to rubbing the burst on. Good luck and it would be nice to see your end results. Cheers, Bob BTW, Here is a shot of my last burst I did. It is a Gibson J40 which I rebuilt for myself and decided to give it a traditional Gibson burst like its big brother the J45. Be sure to post some shots of yours when its done. ![]() |
Author: | RusRob [ Thu May 01, 2014 9:11 am ] |
Having thought about your question, I would most definitely spay a couple coats of lacquer over that sealer. When you use Vinyl Sealer you only have 2 hours to spray the clear on. I use Behlen products but I am pretty sure most vinyl sealers have the 2 hour window. |
Author: | Nick Royle [ Thu May 01, 2014 12:36 pm ] |
I'd recommend sealing AND taping. Worked very well for me. Just have to tape very accurately. |
Author: | dzsmith [ Thu May 01, 2014 6:34 pm ] |
I don't see how an aniline dye could be rubbed onto a sealed surface. Water based would bead up, alcohol based would eat into the sealer? Maybe an oil based dye would work? This is really a question rather than an answer. |
Author: | dzsmith [ Thu May 01, 2014 6:43 pm ] |
RusRob wrote: Having thought about your question, I would most definitely spay a couple coats of lacquer over that sealer. When you use Vinyl Sealer you only have 2 hours to spray the clear on. I use Behlen products but I am pretty sure most vinyl sealers have the 2 hour window. I have heard that as well, Rob, but I have not found any mention about it on Behlens web site. I applied vinyl sealer to a solid body two weeks ago and have not shot any lacquer. I hope I do not have any problems. Thanks for the tip! |
Author: | Glen H [ Thu May 01, 2014 9:51 pm ] |
Sand the sealer to create a mechanical bond if the time has passed Sent from my iPhone using Tapatalk |
Author: | RusRob [ Thu May 01, 2014 10:47 pm ] |
dzsmith wrote: I don't see how an aniline dye could be rubbed onto a sealed surface. Water based would bead up, alcohol based would eat into the sealer? Maybe an oil based dye would work? This is really a question rather than an answer. I have never used dye before so I would have no idea how it would work. I use to to custom painting on auto's and I have done many murals using acrylic artists paint over lacquer and didn't have any problems with it. I would give it 24 hours to dry and spray clear lacquer over it. I have seen 10 year old murals that I did and there was no sign of any problems. But then that is a completely different critter... Again I would still suggest doing some practice pieces first so you know exactly how the materials react with each other. dzsmith wrote: RusRob wrote: Having thought about your question, I would most definitely spay a couple coats of lacquer over that sealer. When you use Vinyl Sealer you only have 2 hours to spray the clear on. I use Behlen products but I am pretty sure most vinyl sealers have the 2 hour window. I have heard that as well, Rob, but I have not found any mention about it on Behlens web site. I applied vinyl sealer to a solid body two weeks ago and have not shot any lacquer. I hope I do not have any problems. Thanks for the tip! Yes sanding the sealer will create a mechanical bond but with lacquers you really want a chemical bond where the 2 coats of finish become one. I will apply my coats of sealer and give each coat enough dry time to allow sanding without gumming up the paper (usually over night). But I do spray a thin final coat of sealer just before spraying the lacquer. Here are the instructions on the can which states to apply clear after 1 hour: http://www.shellac.net/instrument_lacquer_howto.html |
Author: | Ruby50 [ Sun May 04, 2014 9:01 pm ] |
I recently did a hand applied sunburst on Sitka spruce. I used the Transtint dyes in water on a suggestion from someone who does a lot of them and is using alcohol - he thought the water would be better for a beginner and it was pretty simple. I did 5 sample boards (spruce 2X8 from Home Cheapo) and had very good control by the time I was done. I used plastic binding and rosette material to mimic an early Gibson, so scraping took care of any bleeding. I used 3M auto body vinyl tape on the rosette because it would be hard to scrape and it it worked perfectly. Maybe the tape will work on the wood herringbone material. Make some test pieces and go at it. The bad news is that you can't use brushed on water based varnish or shellac because it dissolves the tints (DAMHIKT), so you have to spray a coat of something over the completed sunburst if you are going to brush or French Polish. I reluctantly used shellac because you never know the age or the quality. About 2/3 the way through this set of pictures you can see the sunburst progress: http://www.flickr.com/photos/ruby1638/s ... 130471994/ |
Author: | Glenn LaSalle [ Fri Aug 15, 2014 12:54 pm ] |
Thanks for the update! I too plan on doing a hand rubbed sunburst on one of my next guitars (a Nick lucas inspired guitar). there are a couple of vids/info on the inter web that I was going to use as info: https://www.youtube.com/watch?v=OjlIAq17aVc http://www.mandolincafe.com/forum/showthread.php?55054-Hand-rubbed-sunburst-finish And another that I downloaded, but can't seem to find - its a mando hand rubbed, but had a spruce top. I am looking for this type of look: Attachment: Sunburst.png Glenn |
